Administrators wildweaselmi 0 Posted April 2, 2017 Author Administrators Share Posted April 2, 2017 Ok, not a great update. Good News power steering fixed Bad News Leaking seal on Xfer case for gear selector xfer case vent leaking oil So moved to a SYE by JB conversions a bit ago to help eliminate vibrations in the driveline which worked. Bad news is before the SYE the air build up could slip out the slip yoke seal if build up happens. Now it's sealed tight so the vent is now an escape for the transfer case oil. Moved to ATF since it's thinner than the Mobile Synthetic oil. An option was to put a thicker/wider vent tube or relocate the vent on the xfer case which is what we ended up doing. Moving the vent away from the chain hoping to still allow heat to escape and pressure out but keep oil in. spacer had to be used by alternator since belt was being eaten. will find out in about two weeks Link to post Share on other sites
Administrators wildweaselmi 0 Posted April 16, 2017 Author Administrators Share Posted April 16, 2017 Ok so we are now working. Transfer case is no longer leaking. Transmission was provided by one of Sammons contacts and it seems pretty good (just a little sluggish between shifts).. Currently at Motor City Steel for an ignition upgrade and dyno tune on the Holly Terminator which they are certified to tune. Hopefully next week I should be ready to go. Very excited to see what they can do Link to post Share on other sites
Administrators wildweaselmi 0 Posted April 27, 2017 Author Administrators Share Posted April 27, 2017 Got it back from Motor City Steel. On a 1-5 rating I'm giving them a 3. Some annoying facts about the company. 1. They never ever answer the phone 2. They are slow.. they promise one time and deliver many many days or weeks after. Now why am I giving them a 3. I believe they do good work. Just be patient. If you are in a rush stay away. If they say a week count on a month. If they say a month count on two months. At least double whatever they quote you. They are also a tad on the expensive side. So I got it back and it runs pretty good. I would say I'm at about 75% happy with how it runs. The trans is still a tad sloppy and it stalls every once in awhile when you first start it and finally, the torque converter locks up and you wish it would of waited just a tad longer. On another note, I found out finally how to remove the top on the 91 K5 since its different then the rest because its the only year that comes with seat belts that come down from the top. Open the cover to the seatbelts there are 2 bolts that have to be removed. There's also a plate behind the drivers side seat. Open that and there is a plug in there for the light. Then all that is left is the bolts on the top itself. It is a safety torx They sell the bit at auto zone. It is a size 40. We had to buy the bit because a regular torx will not do it. The bolts have a solid center to them. So get a bit that has the center taken out of it to accomidate the solid center of the bolt. Other than that have someone there to help you gently lift the top off and back. We slid it down to the tailgate and carried it off from there. Below is from a 75 but the cab and rails should be similar. The biggest difference is the seatbelts and electrical hookup for the light. Link to post Share on other sites
Administrators wildweaselmi 0 Posted May 11, 2017 Author Administrators Share Posted May 11, 2017 Prepping for my drive to the Silver Lake Sand Dunes this weekend with some buddies. I still have a trans leak (seems like its coming from the kick down cable but not positive). I checked the trans pan bolts and they are tightened to 12 ft lbs of torque like they should. Its currently got a cork gasket (which may get swapped for one of those nice FelPro gaskets) I just did my first oil change (put in 5w30 Royal Purple.. took 5qts) and used an AC Delco pf1218 oil filter. All joints I saw got some grease so ready to go. Link to post Share on other sites
Administrators wildweaselmi 0 Posted January 3, 2018 Author Administrators Share Posted January 3, 2018 Ok, a little late on my update but sand Dunes was awesome. Only some minor issues of Tire hitting front fender Link to post Share on other sites
Administrators wildweaselmi 0 Posted January 3, 2018 Author Administrators Share Posted January 3, 2018 Went to the Mounds thanksgiving morning. Big to do here. Got pretty muddy which wasn’t my intention. go pro wouldn’t stay fastened to windshield so didn’t get crap for video. insane amount of people. Glad we got there early Link to post Share on other sites
Administrators wildweaselmi 0 Posted January 3, 2018 Author Administrators Share Posted January 3, 2018 So fender issue is now much worse not sure what the solution is. I see a lot of articles talking about either A. Trimming fender (cutting the fender which takes away from the look but adds functionality) B. Moving axle forward by 1 inch (this could also help with vibration in 4wheel drive due to the angle but could cause issues with high steer) Link to post Share on other sites
Administrators dennis 2 Posted January 3, 2018 Administrators Share Posted January 3, 2018 Wow, Kert at DIY4x responds pretty quick to online questions. Seriously like less than 5minutes he also suggested moving the axle forward. But how? A. Drilling the Spring Perches B. Easy Inch Kit Pretty sure if I could move it just one inch forward I would be good but whats the best route? for my lack of confidence I lean towards the easy inch kit which is a plate under your springs that will offset your axle forward roughly an Inch Link to post Share on other sites
Administrators wildweaselmi 0 Posted May 30, 2018 Author Administrators Share Posted May 30, 2018 So in regards to what I decided to do to fix my tires rubbing is nothing for the moment. Instead I took the top off the Blazer (its 90+ degrees out) and learned you should never do this by yourself.. it was HEAVY. Luckily I didn't break any of the custom glass windows in the hard top when I dropped it.. a couple times. BUT luck ran out real quick when I discovered how bad the rust is that was hidden with the top on. Let me upload some photos so you can feel my pain Link to post Share on other sites
Administrators wildweaselmi 0 Posted May 30, 2018 Author Administrators Share Posted May 30, 2018 Just dropped the Blazer off at around 4:15pm today (5/30/2018) to get that rust repaired (estimate is $1100 - $2500 and two weeks) 112 State Street Davison, MI 48423 Open: Mon. – Fri. 9 a.m. till 5 p.m. 810-412-4215 Link to post Share on other sites
Administrators wildweaselmi 0 Posted June 1, 2018 Author Administrators Share Posted June 1, 2018 Let me tell ya its difficult to walk out into my garage and not see my Blazer there. I wonder how often you can stop by and check on progress without becoming a pain in the ass. Pretty sure I am going to just swing by today and see if they started on it. Anxious to see the progress and how much metal is gone after they sand blast all the rust off. Link to post Share on other sites
Administrators wildweaselmi 0 Posted June 1, 2018 Author Administrators Share Posted June 1, 2018 Ok so I stopped by MMC to see if they had a chance to start working on the Blazer and to my surprise they have already started, so that's the good news. Now the bad news is apparently TONS of rust. As they are getting into it, they found it would be great to find a new skin they could just lay down but no one makes it for the Blazer (including LMC Truck) so they have to custom make everything. Will keep you posted. Just as a reference point, I did find some cool sites for auto body parts https://www.autobodyspecialt.com/cgi-bin/commerce.cgi?search=action&category=0111 This one shows only to 1986: http://www.goodmarkindustries.com/chevrolet-k5blazer-parts.aspx RPS: http://restorationpartssource.com/store/K5 Blazer_1981_1991_Sheet_Metal_and_Body_Parts.htm GM Discount Parts I always check because I love OEM but most of the time they don't have what I need but its a great place to get part numbers that you can search for on the internet https://www.gmdiscountpartsnow.com/a/Chevrolet_1991_Blazer-Silverado-57L-Chevrolet-AT/_51505_6403488/ROOF--COMPONENTS-EXTERIOR-TRIM/GC1120.html OEMcats is a great site for OEM parts: http://oemcats.com/oem-parts/355616.html Car-Part.com is a great search of all junk yards in United States. You can sort my closest since many don't ship big parts. Link to post Share on other sites
Administrators wildweaselmi 0 Posted June 9, 2018 Author Administrators Share Posted June 9, 2018 So no outer roof anywhere so Carl from MMC took the challenge. I stopped by yesterday and man does it look great. Looks factory to me. Should have it either Tuesday or Wednesday and I’ll share pictures then Link to post Share on other sites
Administrators wildweaselmi 0 Posted June 14, 2018 Author Administrators Share Posted June 14, 2018 MMC collision in Davison did a fantastic job fixing the roof. Check out the after pictures here. It was around $2500 for all the work. I’ll try and get pics when they were working on it. I may have them paint my blazer in the winter Link to post Share on other sites
Administrators wildweaselmi 0 Posted June 29, 2018 Author Administrators Share Posted June 29, 2018 The 700R4 just isn't right so I brought the Blazer to someone my dad knows "Dan the Trans man" since he did such a fantastic job on getting my dads 40 tuned in (as far as Transmissions go). After about two days he looked it over and several bolts were loose that hold the trans as well as the bolts on the pan. But what worries me is when he drained the fluid he found a bunch of brass or copper shavings in the oil. He said its more than likely from the torque converter (which I already blew up a torque converter that Frayleys Transmission put in). Dan's estimate to rebuild it the way it should be built is about $2000 and he needs three days. Going to table that for now and just drive it. Dan also had to replace the governor. The green gear at the end was very worn out. It drives pretty good now but I don't feel I have the 4th gear like I use to but could all be in my head. Link to post Share on other sites
Administrators wildweaselmi 0 Posted June 29, 2018 Author Administrators Share Posted June 29, 2018 It looks like I need to update my rear bumper. The weight of a 37.5" tire is just too much for the Offroad Ltd Bumper. So I am looking at what DIY4x offers for a rear bumper tire carrier and they have one option which is this bumper I like how durable it is but I have some minor issues in comparison. CONS I don't like the lights on angle, prefer them to be straight (silly I know) I love how the OffroadLtd Bumper had a place for my jack. Not sure how to work that in here Bummer for me is I can't have my tire cover anymore with this design. PROS No movement from bumper with weight of tire like there is with OffroadLtd Bumper Easy to get tire Way easier to get access to tailgate So we'll see what happens. Its all about money. Link to post Share on other sites
Administrators wildweaselmi 0 Posted July 3, 2018 Author Administrators Share Posted July 3, 2018 Changed Oil in my Blazer today. (325,288 miles) 5 quarts of Royal Purple 5w-30 (I have one more 5qt container then I'll probably move to Mobile One since it can be found everywhere and it performs as good if not better than Royal Purple) Advance Auto didn't have my AC Delco PF25 Oil Filter so I went with a K&N HP 2002 filter (last time I get a K&N Filter and think I'll use FRAM next time) Check out the Oil Filter Cross Reference site here Link to post Share on other sites
Administrators wildweaselmi 0 Posted October 8, 2018 Author Administrators Share Posted October 8, 2018 Ok need to update the "To Do List" I have to figure out my HVAC and why not getting air movement. Pretty sure the duct work is messed up. Wish some of these after market companies just made replacement (rebuild kit).. not Vintage Air.. had that in my cutlass and it totally sucked. Roll Cage (seems silly and very expensive but I won't go on some of these trails with my kids in the back without one. Custom Dash (make it more usable). I was always trying to keep everything original, now I just want it functional Transmission. Yea, still fighting this battle. It's not horrible but I don't trust it after Dan the Trans man found copper shavings at the bottom of the trans pan... he said more than likely the torque converter is going bad (again). Storage. I would like to add some sliding storage to the back so I can keep many of my supplies secured (especially when the top is off) Rear Bumper. Get a more functional heavy duty bumper that I can carry my spare without worrying about the weight of it ripping it off. Center Console. Need somewhere to keep all your loose papers, HAM Radio, etc. Rock Sliders (DIY4x) Link to post Share on other sites
Administrators wildweaselmi 0 Posted August 19, 2019 Author Administrators Share Posted August 19, 2019 Rough time with putting the hard top rubbers on. No one really has any pictures First thing to note is 4 seals are needed to put the K5 hard top back on left side rail right side rail note: both attach to the bottom of the hard top and should be attached using something like 3M adhesive... spray on rubber and when tacky (not just wet) attach to fiberglass top and hold into place.. awesome if u have clamps) inner cab (this seal attaches to the cab with adhesive) outter cab (this seal attaches directly to the hard top) note: in the picture you will see black where I attaches the outter cab seal for my soft top but had to remove it to but my hard top back on) in this picture above you can see the inner seal is in place. below picture is of the fiberglass hard top and you can see the black is where the old outter seal was. here are pictures of the outter seal. skinny side goes towards hard top and the little lip faces down (you will see that you can tuck that lip behind a groove found in the top. The groove isn’t all the way but spaced out like corners and stuff) Link to post Share on other sites
Administrators wildweaselmi 0 Posted August 19, 2019 Author Administrators Share Posted August 19, 2019 I really like this cluster from Dakota Gauges: RTX-79C-PU-X ($1300) Link to post Share on other sites
Administrators wildweaselmi 0 Posted August 19, 2019 Author Administrators Share Posted August 19, 2019 Things on To-Do List include: PAINT JOB: $10,000 TRANS: $2000 GAUGES Link to post Share on other sites
Administrators wildweaselmi 0 Posted August 20, 2019 Author Administrators Share Posted August 20, 2019 Chevrolet/GM K5 Blazers, Jimmys, and Square Body Truck part locations DIY 4X (Pronounced DIY 4 by), custom fabrication parts such as bumpers, all kinds of mounting brackets, etc. for square bodies. EXTREMELY WELL MADE PARTS! Truck Shop A wide variety of hard-to-find restoration parts for square bodies. LMC, Truck Parts and Truck Accessories for restoration. Filthy Motorsports, King Shocks, Differentials, Off-Road Performance & Racing, Etc. Rock Auto, Great Prices, Easy to find the parts for your vehicle, Easy Return Policy. Summit Racing, general parts and racing/performance parts. Rocker Switch Pros, really nice switches. Hillbilly Wizard, Axles, Axles, Axles, heavy duty 14 bolt full floater 1 ton, custom axles, etc. Off Road Design, custom suspension, 4-Link suspension, hard-core vehicle components, etc Stock Interiors A1 Electric Harris Performance, INC, good info on tweaking out performance from the TBI engines. GMPartsGiant.com AMSOIL – the best stuff you can put in your engine! Join their Preferred Customer program ($10 for 6 months, $20 for 12 months) and save up to 25% and get free shipping on orders over $100. Link to post Share on other sites
Administrators wildweaselmi 0 Posted February 8 Author Administrators Share Posted February 8 I finally saved enough change to buy another transmission (4th attempt). This time going through a company instead of local mom and pop shops. Ordered: 2021/01/31 Message.pdf Link to post Share on other sites
Administrators wildweaselmi 0 Posted Monday at 01:28 PM Author Administrators Share Posted Monday at 01:28 PM Dropped off my new Performa Built 700R4 Trans with new trans cooler to my buddy Al to have him swap transmissions. He's also helping me figure out how to add a rear emergency/parking brake since I don't have one once I moved to calipers from drums. We believe we are going the route that Lug Nut 4x4 has for around $280. It uses Cadillac Eldorado calipers that have the attachment for the emergency brake cable. Issue is these calipers are getting harder and harder to find so I may order another set of calipers from someone to just have in my inventory. Quote The kit features: Calipers with a clever cable operated mechanism to actuate the brakes. The calipers should work just fine with your OEM parking brake cable. Proven parking brake design is based off of 1976-1978 Cadillac Eldorado calipers (no longer in production) which allowed the parking brake to be set with a standard cable. The mounting dimensions of these calipers are exactly the same as the JB6/JB7 brake calipers used in almost all of our kits — these calipers will mount on any brackets that accommodate the JB6/JB7 caliper You can add substitute these calipers into most of our disc brake conversion kits, or order them separately here. Whether you need a parking brake for inspection or for piece of mind, this kit works great. Finally, while its up on the hoist, fixing my leaking gearbox. It appears the retail stores (Adv Auto, Autozone, O'Reillys) all carry horrible quality gearboxes. Mine just split right down the seem. Garbage! Also I just learned that AC Delco are all made in Mexico. I always thought they were an American company. Surprise! At least its not the poor quality parts most retail stores get from China. Link to post Share on other sites
Recommended Posts
